Cylinder Head Cover Mounting Nuts and OCD
Oseanosea
Thu Jul 04, 2019 2:09 am
I have an ‘85 318i 5spd, M10. My cylinder head cover has been leaking just the very slightest bit of oil from the #2 mounting nut since I bought the car last year. Car runs fine.
A couple days ago, OCD set in and I decided to check to make sure that the mounting nuts were properly torqued. According to Bentley’s the torque specified is 15 +/- 1.5 Nm or 11 +/-1 ft.lb.
The #2 nut was quite loose. OCD dictated checking the torque of all 6 mounting nuts. I followed the specified tightening pattern, but could not confirm proper torque despite trying with three (yes, 3) different torque wrenches (all are the twist/click type).
I stopped tightening for fear of accidentally making things worse by snapping a stud, warping something etc. I wish I had left the thing alone, but we’re past that now.
I bought a shiny new, sensitive, calibrated expensive torque wrench and now I am pondering what to do. So how deep is the crap I’ve found myself in?
My questions are:
• Should I loosen all the nuts and start over?
• If so, can I attempt to re-torque all 6 nuts or do I need new ones?
• If I cannot confirm they are torqued properly do I pretend everything is fine? Or do I need to disassemble everything and start over, replacing parts? If so, what parts should I replace?
Seriously, what is my next step? I am afraid to make things worse trying to fix them.
Any advice is very welcome, snarky humor also welcome.
“Keep lowering your standards until goals are met.”
Oseanosea
Thu Jul 04, 2019 2:30 am
I guess I should have provided photos demonstrating the condition of the cylinder head cover and the associated gasket, which appears to be made of cork.
Here they are:
Cloggy Saint
Thu Jul 04, 2019 11:23 am
You're over-thinking things! I don't think I've ever used a torque wrench on the rocker cover nuts, just tighten them to an obviously sensible degree and keep an eye on the gasket area. If there's any oil seeping out re-check the nuts and give them an extra turn. It will be clear to feel if you're over tightening.
Oseanosea
Fri Jul 05, 2019 8:26 pm
Thank you! I appreciate your help!
BenHar
Fri Jul 05, 2019 10:28 pm
If the gasket has been leaking for a while, change it.
Ben
Oseanosea
Sat Jul 06, 2019 3:48 pm
Thank you, I will do that when I change the belts and water pump. I also want to remove all the old adhesive from the bottom of the bonnet. The center piece of insulation has fallen off and refuses to stay attached.
