grumbly whine in 1st & turning
Captain_Birdseye
Sat Jan 06, 2018 4:41 pm
... when cold. Seems to be related to power steering but could be gear/box problem? What should I check? Many Thanks.
ChrisHC
E30Zone Contributor
Sun Jan 07, 2018 12:08 am
My power steering groans horribly when I first use the car after a period, no idea why and it soon wears off.
Yeti
Mon Jan 08, 2018 12:17 am
disconnect the fan belt to stop the pump turning to see if the noise stops if not its something else . if so I would look at a fluid change.
Mon Jan 08, 2018 12:44 am
yeti wrote:disconnect the fan belt to stop the pump turning to see if the noise stops
Probably a better idea to remove the steering pump belt!
Fan belt off to check for alternator and water pump noise.
Contours
Mon Jan 08, 2018 4:10 pm
Sounds like a loose power steering belt. The steering shudders/grumbles initially after start up until the pump builds up pressure and is then ok while driving. This behaviour repeats until the belt is sufficiently tightened. Have a look anyway.
Captain_Birdseye
Tue Jan 09, 2018 3:03 pm
Thanks chaps. By the by the steering always makes a high whine on full lock.
Tue Jan 09, 2018 8:52 pm
Captain_Birdseye wrote:By the by the steering always makes a high whine on full lock.
This is normal - the pressure in the system increase dramatically at full lock, which is why you should never maintain full lock for more than a few seconds.
Captain_Birdseye
Sun Jan 14, 2018 5:58 pm
Thanks chaps, everything looked fine so I had a fluid change done and as you can guess it fixed the problem.
