MTech II Steering Wheel Fitting
jas325sport
Fri Feb 10, 2006 1:37 pm
I have just bought a mtech 2 wheel to fit to my 89 sport to replace the mtech 1 fitted but I am having trouble fitting it.
I thought it was a straight swap as the car is an mtech 2 version but the new wheel will not fit and does not seem to have the splines for the steering lock to fit into.
The steering lock mechanism seems to be in the way
Do I require a boss to fit this wheel?
any help is appreciated.
Jason
Cloggy Saint
Fri Feb 10, 2006 1:44 pm
Are you sure you haven't bought an E36 tech 2 wheel?? You shouldn't need a boss.
Gwynleym10
Fri Feb 10, 2006 1:45 pm
It should be a straight swap providing you have the correct mtech 2 wheel.
Ones from E36 DO NOT FIT and you can't do anything about it. Also they are not worth much...
London 2 Cape Town
www.Overlandinthesun.com
jas325sport
Fri Feb 10, 2006 1:48 pm
Was sold this as an E30 mtech.
got it off eBay from BMBITZ
Cloggy Saint
Fri Feb 10, 2006 1:49 pm
You need to have the key in the ignition to disengage the steering lock or the wheel won't go on......
jas325sport
Fri Feb 10, 2006 2:22 pm
have just checked part no's on ETK and looks like this is a E36 wheel aaaaarrrrrggggggghhhhhhhh.
I will have to send it back.
I have noticed BMBITZLTD have another wheel up for auction the same as this one also described as E30.
Cloggy Saint
Fri Feb 10, 2006 2:26 pm
I'm sure you're not the first person to be caught out by this. I'm always seeing tech II wheels being advertised as fitting E30, E34 and E36 :x
jas325sport
Fri Feb 10, 2006 2:29 pm
this one was soley described as for E30 so beware of the other advertised.
lets be careful out there.
(hill street blues repeats on more4, nuff said)
dsio
Fri Feb 10, 2006 4:37 pm
Its even more confusing buying them for E34s. The early E34s, from 87-91 use the E30 spline, and don't seam to have airbags.
The E34s from 91-96 have the later E36 spline.
So you can buy an E34 MTech 2 and it may or may not fit your E30 depending on the year and other factors.
