I have been reading this forum two years from now, helping me with a lot of issues on my 318i and hopefully now with a M3.
The car was parked and saw little use in about 3 years (less than 3k miles).
Since I got it, been doing basic maintenance that was neglected like fluids, filters, bands, sparks, rotor, coil, etc..
And other mayor like new new cats, intake gaskets and all hooses.
Finally got to the part to regulate idle, now sits about 900, no gas smell, runs well, getting 9lts/100km on mix use (highway and city).
Got myself a carbtune to synch each throttle body since someone messed up (also the CO screw), because the car had an air leak and the best solution was to move everything to compensate that leak.
Car warm, TPS disconnected and in a loop, the readings on cyl 1 an 2 were too high compared to 3 and 4.
Now CO screw is closed so the air bypass between the ITB, thats the best combo I got with the car idling right, not stalling or so.
This is the best result I got:
Now I ask you guys, what should I try? balancing the throttle bodys? do a valve adjustement?
Any idea on this matter?
Thanks a lot[/img]
