what relay for k4. mine is ford??
grants50
Thu Oct 08, 2015 5:30 pm
My dipped beam doesn't work. Bulbs are fine so I think relay has given up. The relay in k4 is a white ford 5 pin relay.
I've looked on car parts but there's two listed with 5 pin.
What one do I need please?
http://www.eurocarparts.com/mobile/car- ... -solenoids
Thu Oct 08, 2015 7:03 pm
You need a double pole, single throw relay (DPST), with the pins in the right places. Since the 'specifications' on the ECP site don't actually give the specification, I've no idea which it is, although I suspect it's none of them.
BMW relays rarely fail, so I suggest you get a second hand one from one of the traders on here.
grants50
Thu Oct 08, 2015 7:38 pm
Traders on here, awesome cheers pal.
