2 are 10x17h2 et15
2 are 8.5x17h2 et15
Will these fit a standard pre facelift e30?
i'm running 17x8.5 compo cxn's all round with a 20mm spacer & have no problems with the hitting the strut or rubbing the arch. & my sport is lowered 60/40.zd3bx wrote:Pretty sure 8.5J will be hitting the struts on the front, but if you space them out, then most likely will be rubbing on the arch...
These sizes are way too big and unnecessary, imo. Even if you manage to fit them, the car will handle like a cow on ice.
