After injectors being rebuilt, problem still exists. Engine shakes a lot and feels like missing here and there at idle.
So, I connected the M40 to the BMW DIS and found some strange data. Viewing the live status of the engine sensors, timing, engine and air temperature etc seems ok, except for the injection time. TIS says injection time when warm should be around 2-3ms, but I am getting 4.5ms which seems too high. Load signal is ok at about 2ms.
What can cause the ECU to open so much time the injectors although load and idle speed is ok?
Thank you!
Edit: For the ones that say our cars are too old ;)
