Bonnet won't open
Muzz2676
Tue Feb 03, 2015 10:15 am
Went to get the engine number, pulled the lever on the passenger side footwell and nothing happens, no clunk and bonnet won't open. First time I've tried to open it since bringing the car home.
How do I get round this?
age
Formerly twist316
Tue Feb 03, 2015 11:09 am
if you look through the grill on the passenger side to the left of the headlamp you will see the bonnet latch, there is a fail safe built into the latch , you can use a long flathead screwdriver to open the boonet
M40 rightness if you can get to 6000rpm noone can hear your tappets
Muzz2676
Tue Feb 03, 2015 11:11 am
age wrote:if you look through the grill on the passenger side to the left of the headlamp you will see the bonnet latch, there is a fail safe built into the latch , you can use a long flathead screwdriver to open the boonet
Phewwww cheers mate, will give that a go
Tue Feb 03, 2015 12:40 pm
Get someone to pull the lever while you push down on the bonnet, just to the side of the pass lamp as said, it probably just needs cleaning with WD40 and then oiling
Muzz2676
Wed Feb 04, 2015 10:45 am
B'stard won't open, put big flat head in the hole but no luck
Willeh
Wed Feb 04, 2015 1:13 pm
Remember if you open it with a screwdriver, make sure you don't keep your head near the grille.
Muzz2676
Fri Feb 06, 2015 8:23 pm
DanThe wrote:Get someone to pull the lever while you push down on the bonnet, just to the side of the pass lamp as said, it probably just needs cleaning with WD40 and then oiling
I got the missus to pull my lever while i pushed down on the bonnet, worked a treat! I'm going to get some 3 in 1 and lube it up
maxfield
Fri Feb 06, 2015 8:38 pm
Make sure you work the catch with a screw driver aswell.
nick28
Thu Feb 12, 2015 10:22 pm
'I got the missus to pull my lever while i pushed down on the bonnet, worked a treat! I'm going to get some 3 in 1 and lube it up'
8O
