I have a 1990 320i SE with 45mm front struts, I've got hold of some 51mm fronts but can I use the calipers/discs that I have or will I need to buy 325i specific ones? The wiki isn't very clear on this so could those that have swapped over please enlighten me?
Jamie
Brake calipers/discs 320 vs 325
bab-91
The 320i has the same brakes as a 325i and didn't they have the same 51mm front struts?
IG - bab91
IG - bab91
bab-91
maxfield wrote:The struts will bolt in perfectly fine. And your pads and discs will bolt up fine.
As I understand. 320i's came with bigger struts and vented brakes if it had ABS?
Zone Wiki wrote:On the plus side, it shares the same larger 51mm struts and vented front discs as those models, while Touring and Cabriolet models will have rear discs as well. All models were fitted with front and rear ARBs.
http://www.e30zone.net/e30zonewiki/index.php/320i
IG - bab91
IG - bab91
Thanks mate.maxfield wrote:The struts will bolt in perfectly fine. And your pads and discs will bolt up fine.
The wiki isn't 100% accurate as I have 45mm on the front of mine (non ABS) this is why I'm clarifying the brake fitment.
Solid discs and vented discs require different calipers.
Cabs, tourings, 325i and 318iS all came with 51mm struts, vented front brakes and rear discs.
But I think only 320is came with the above if they had ABS.
bab-91
Rav335uk wrote:I'm sure only cabs had 51mm struts as standard.
Maybe the wiki should be changed?
IG - bab91
IG - bab91
