Gearbox reluctant now oil changed.
Sounds to me like the oil is too thick especially as you say it improves when it gets warm, i had this on a previous car after having a suposad specialist fit a new clutch and it turned out he had put the wrong grade in as it was cheaper
so i did a search and found this nugget of info from 'oilman'
"For the gear box I would recomend the Silkolene Syn5 75w-90."
he recomended that for a 325 so that could be the ticket
- Brianmoooore
Had the same problem with one of mine. Think ATF had been used before instead of 80W.
Demlotcrew
Im using a 75w90 and the gear changes are very hard when cold but i dont care as when it heats up its just right, with ATF you get easy gear change when cold but when 'giving it some' the changes ger harder as the fluid heats up.
Andrew
Andrew
I got eaxctly the same problem with mine now. If i let the engine warm up for 5 mins before i drive it seems ok, but who the hell wants to do this every time !? i'll have to get mine changed i reckon
when i change the oil in my diff it wined ever since,and im talking WHHHHHIIIIIIINNNNNNNNEEEEEEEEEE!!! gonna get me another diff i think,never change the oil when it comes to cogs! if theyre happy,leave them alone!!
This is what i am starting to think! I would have thought that changing the oil made things better but it doesn't seem so.telski789 wrote:when i change the oil in my diff it wined ever since,and im talking WHHHHHIIIIIIINNNNNNNNEEEEEEEEEE!!! gonna get me another diff i think,never change the oil when it comes to cogs! if theyre happy,leave them alone!!
Thanks for the replies
