After a bit of help if anyone knows.
I've bought a e28 oil filter housing for my m30 powered e30 cab as I'm in the middle of fitted a eaton SC and didn't have the clearance for the standard housing.
I've been reading that in order to use the e28 housing you need to block one of the drain holes with a bolt. The only thing I've found on the subject is not very clear on what I need to do.
Can anyone help with this or done it before??
