washers stuck on
beefy
Tue Jan 17, 2006 4:41 pm
hi when i use my wipers the washer jets come on and will stay on until the bottle is empty.
also check light for washer bottles stays on all the time
any help apperciated cheers
woodysjw
Tue Jan 17, 2006 5:32 pm
hello mate,
open the fuse box and u should see a long black realy take it ou and make sure the connections are all nice and clean and put back in should be ok give it a wiggle about when refitting. also check inside the washer bottle and make sure the sender is the right way up.
796 - 1989 Motorsport Edition
sabrje
Tue Jan 17, 2006 5:35 pm
Sounds like the relay, mate. Its either the largest one in the fuse box (black ~8x3x3 cm), or if you have headlight wipers it could be the extra relay attached to the washer reservoir. If its the later you can disconnect that and windscreen washing will still work. Probably best to clean all the contacts and then try again. Good luck
Tue Jan 17, 2006 11:17 pm
Windscreen washers should still work from the column switch with the wiper relay removed, so if they keep working continuously with the relay out, then the problem is the column switch, or a short to earth in the brown/black wire leading to it.
If pulling the relay stops the washers then it probably is the relay.
NIX
Wed Jan 18, 2006 12:18 am
Just a usless post to keep track of this thread. Same has happened to me but not for a while now, so I want to be ready with knowledge when/if it does.
scottybeemer
Wed Jan 18, 2006 1:37 am
woodysjw wrote:hello mate,
yes that!or relay cud be phucked
"you aint gonna take me alive, copper"
