Eibach springs fitted, now lower on front than back?
hillbilly30
Wed Feb 19, 2014 8:38 pm
So as above, fitted to my 318is on standard shocks, definitely gone down more on front than rear?? Haven't got any pics to show it but I would say rear has gone down 10mm and front has gone 35mm, is this normal? :?
Wed Feb 19, 2014 9:32 pm
Are you sure you've seated the springs into the rubber pads correctly?
blondboy84
Wed Feb 19, 2014 9:36 pm
Brianmoooore wrote:Are you sure you've seated the springs into the rubber pads correctly?
I'm pretty sure that's the problem.
I have Eibachs on my 325 and no probs...
Astra bertone vert
mx5
1990 e30 325i SE+1990 e30 320i Touring
hillbilly30
Wed Feb 19, 2014 9:47 pm
I think so, you talking about the rears? I've driven a few miles with them fitted so would have thought they would have seated by now? Do eibach do two different heights?
leeparkes
Wed Feb 19, 2014 10:17 pm
You could have touring/cab rear springs (heavier car on the rear)
Or a 60/40 drop (or both)
Is there any codes on the springs?
hillbilly30
Thu Feb 20, 2014 6:58 pm
I've removed one of the rears today and there is no difference in height between them and the old standard ones, any ideas people?
Thu Feb 20, 2014 8:06 pm
Sounds like your old springs were overly compressed, for example, the car has been used for towing or had heavy loads in the boot for long periods of time
hillbilly30
Thu Feb 20, 2014 8:35 pm
Yea that sounds fair enough, the car has over 90k on it. Though I still can't understand why I'm getting the "rake" look with the set fitted?
It's not a great pic but I think the issue can be seen.
Is there anything else I can do to drop the rear?
Edit: no it's a crud pic and you can't see what I'm talking about :D
rich318i
Thu Feb 20, 2014 9:28 pm
get the car 3 up plus driver 4 and take it out. It should settle
The front looks like mine on H&R's sports. On my rears 15 bbs are level with the front small amount of tyre under the arch
20mm drop i believe with the H&R all round
Dave_M3
Thu Feb 20, 2014 9:39 pm
Eibach springs give abit of a rake look anyway but it's only slight. personally, I like it :)
Your old springs could have been just very sagged as Dan says and now your just not used to how an E30 is suppose to sit :)
I'll see if I have any pics from the side when my iS was on the B12s
hillbilly30
Thu Feb 20, 2014 10:41 pm
This is the best example I can find of how my car sits
Dave_M3
Thu Feb 20, 2014 11:41 pm
That's sitting perfectly in my opinion.
Even standard E30 318iS mtec springs have a nice rake to them.
This is how my other iS used sit on standard suspension
suedenim
Fri Feb 21, 2014 1:46 am
hillbilly30 wrote:This is the best example I can find of how my car sits
This is how my 4 pot sits on Eibach 40/40, std dampers/15" wheels 55 profile tyres.
1982 E21 316 Baltic Blau
1989 318i 2 Door Sterling Silber
Feedback: http://www.e30zone.net/modules.php?name ... highlight=
hillbilly30
Fri Feb 21, 2014 7:05 am
Will post pic of mine later today for judgment, Dave-m3 I think mine is similar to your pic on rear but is still lower on the front by maybe 25mm,
Quaser
Fri Feb 21, 2014 8:52 am
DanThe wrote:Sounds like your old springs were overly compressed, for example, the car has been used for towing or had heavy loads in the boot for long periods of time
probably loaded with subs init
hillbilly30
Sat Feb 22, 2014 3:32 pm
Well it's sorted! Stripped the whole thing down and then rebuilt. All seems well, not that I could see an issue before but it definitely sits better now
What do you think?
Thanks for all posts 8)
Sat Feb 22, 2014 10:19 pm
Not much else it could be, if all you've done is taken it apart and put it back together.
Dave_M3
Mon Feb 24, 2014 1:20 pm
hillbilly30 wrote:Will post pic of mine later today for judgment, Dave-m3 I think mine is similar to your pic on rear but is still lower on the front by maybe 25mm,
Definitely something was wrong in how the springs were seating on the pads so then as mine had standard Mtec springs all round in that pic and iirc, I don't think I had the carpet, rear seats, boot trim and things in it when that photo was taken either was had that iS stripped out to make it a trackcar at the time.
My guess is the spring pads weren't sitting down around on the bump stops in the trailing arm an body properly.
G-Bear
Tue Feb 25, 2014 7:43 am
As did mine..
Jamie8GTi
Sun Mar 09, 2014 10:38 pm
reading this post has me sold on the eibach springs! both those pictures look identical to my desired look!! :D
