E30BeemerLad wrote:I've never really been inspired by the brakes on my 325, discs have plenty left on them (grooved & drilled too), new pads, rest of the system looks to be in good order with new master cylinder etc about 3 years ago.
I think if you have been driving more modern stuff, there is just no comparison. Even getting into a P reg 406 td I nearly found myself peeling my face from the windscreen on the first dab of the brakes.
Pedal pressure has nothing to do with how good a cars brakes are. Have you ever driven a single seat race car? Braking power like you wouldn't believe, but you nearly have to dislocate your hip to apply it.
I regularly drive a couple of modern cars as well as my E30s, and the E30 brakes are every bit as good as the modern ones.
Your new brake master may be a clue to your problems, if the cross car pull rod wasn't adjusted properly. Adjust it so it pushes the brake pedal up just short of the stop.
If that doesn't sort it, then you have air in the system, or swelling brake hoses, or a caliper/disc/hub problem which is pushing a caliper piston too far off the disc, or a combination of all three.
