central locking
ameetgill1
Fri Dec 13, 2013 7:28 pm
Guys my central locking is not working. Checked the fuse it was blown, I replaced it but no play. I tried locking the boot but it was no good.
What could the issue be. The key is turning but its not catching.
Fri Dec 13, 2013 7:43 pm
Have you done the red/black mod??
Fri Dec 13, 2013 7:48 pm
does the central locking relay click if you unplug it then connect it again ?
pud1
Fri Dec 13, 2013 7:56 pm
...module, microswitches, pico-fuse on module, wiring loom...etc..etc..
look at wiki ..
Fri Dec 13, 2013 8:06 pm
Does the car have a fully installed OBC?
PLEASE POST TECH. QUESTIONS IN THE CORRECT FORUM!
ameetgill1
Sun Dec 15, 2013 9:57 pm
Everything was had new interior fitted and Windows adjusted. I may disconnect the battery put the fuse in again hopefully it will work?
Sun Dec 15, 2013 10:49 pm
ameetgill1 wrote:Everything was had new interior fitted and Windows adjusted.
Locking ECU isn't nearly sophisticated enough to lock up (no pun intended) and be reset by interrupting and reconnecting power.
