how do you check if viscous fan is working properly
dannydrifter
Wed Jul 17, 2013 11:03 pm
having a little trouble with cooling and been advised to check the coupling on the viscous fan. not sure how to check this. help would be greatly appreciated.
jmc330i
Wed Jul 17, 2013 11:14 pm
http://www.e30zone.net/e30zonewiki/inde ... ooling#Fan
I've never seen anyone actually shred a newspaper with the fan (Ive seen some fingers get ripped apart though 8O ) but the difference between the cold and hot tests should be fairly obvious.
James
'91 325i Sport
'93 318i touring 16v
TPS
Wed Jul 17, 2013 11:16 pm
Get a rolled up newspaper, stick it in the fan, when the engine is running, if the newspaper rips then its fine, if not, its had it. Another way if it overheats in traffic, but is ok when moving, then its knackered.
dannydrifter
Wed Jul 17, 2013 11:35 pm
nice 1 jmc330i this will be my first job tomorrow. many thanks, il be keeping my fingers well out the way :D
dannydrifter
Wed Jul 17, 2013 11:42 pm
yeah its fine when on a run just when left on idle it creeps up to 3/4 on gauge. also rad pipes go a bit hard. :( il try the newspaper test tomorrow and il let you's know how I get on. thanks again for your help guys :D
dannydrifter
Thu Jul 18, 2013 9:18 pm
done the newspaper test and very glad to say it was the viscous fan that was knackered :D for a while there I thought it was the head gasket. thanks again for your help guys
