Heater matrix can u help
helmi25cab
Mon Jul 08, 2013 2:23 pm
Can anybody help wit remove of this part as I'm strangling to undo the nuts tried everything even pulled the grommet out thought will be able to get the nut from the front of the car but no luck was wandering may b the is Easyier way of getting this part off as you can see is leaking wit antifreeze any help will b most apriciated thanks!!
Helmi
Grrrmachine
E30 Zone Wiki / Team Member
Mon Jul 08, 2013 3:42 pm
Taking the glovebox out makes that job a lot easier.
helmi25cab
Mon Jul 08, 2013 4:28 pm
Yeah clove box is out!!
helmi25cab
Mon Jul 08, 2013 4:45 pm
Fuck!!! nowI have snap the pipe help need a new 1
suedenim
Tue Jul 09, 2013 10:41 am
Iirc I've gone through the engine side with an extension. Make sure you change the o rings, there are four to do both pipes. people will recommend using the gen BMW ones, although they have replaced the part with normal radiused o ring compared to the original flat type, so any quality o ring will do the same job imo.
1982 E21 316 Baltic Blau
1989 318i 2 Door Sterling Silber
Feedback: http://www.e30zone.net/modules.php?name ... highlight=
Tue Jul 09, 2013 2:14 pm
Those nuts can be undone with an appropriate size ratchet ring spanner, or by a short extension from a 1/4" socket set.
helmi25cab
Tue Jul 09, 2013 10:47 pm
Too late now because I have snap the pipe is anyone breaking one cash waiting many thanks for your help much apriciated need one ASAP
