Hub modification?
djhanks
Wed Jun 26, 2013 7:39 am
Can someone point me in the right direction on hub modification to increase lock on my e30?
What else is needed to be modified in order to run 'em?
People keep saying other things need changing but they don't know what...
zaust
Zone day release
Wed Jun 26, 2013 9:10 pm
You need to start off with a rack that will give you the desired lock your after before you can look at the hub/leg/offset needed.
Best way is go find a rack, ie from a TX1, make it fit then work from there.
M30 Tech 1 Touring on gas.
djhanks
Wed Jun 26, 2013 9:20 pm
I'm currently running an e36 rack at the moment :-)
davethegoat
Wed Jun 26, 2013 9:31 pm
There's some info here. I'd be having a very good man with a tig welder doing any of the welding on steering suspension parts if you decide to go that way!
http://www.e30zone.net/modules.php?name ... ering+lock
djhanks
Wed Jun 26, 2013 9:36 pm
Thanks a lot for sourcing that out :-).
I've got a few people who do a lot of custom and bespoke parts so it shouldn't be too hard for them to do ;-) (I hope)
davethegoat
Wed Jun 26, 2013 9:43 pm
N.P's. :)
BATTS91
Thu Jun 27, 2013 11:44 pm
Me im going standard e36 hubs with modified knuckles , much better setup if you ask me , with lots of other un mentiond mods to suit :)
GB69
Fri Jun 28, 2013 12:06 am
BATTS91 wrote:Me im going standard e36 hubs with modified knuckles , much better setup if you ask me , with lots of other un mentiond mods to suit :)
Will standard e36 front hubs work? I've only ever found people saying e30 M3 or e36 M3 evo hubs.
