Diff removal
Andy-M
Sat May 18, 2013 5:22 pm
Any top tips on getting the top two retaining bolts undone. There no room to get my big bar between the top of the bolt and the floor. Even swearing at it didn`t work........ :roll:
Grrrmachine
E30 Zone Wiki / Team Member
Sat May 18, 2013 5:29 pm
Ring spanner, then a second one locked on to it as an extension.
jimbom30cab
Tech 1 freak
Sat May 18, 2013 5:31 pm
with lots of WD40
maxfield
Sat May 18, 2013 5:37 pm
Grrrmachine wrote:Ring spanner, then a second one locked on to it as an extension.
That!
They will be tight and there's a good chance your going to skin your knuckles.
Andy-M
Sat May 18, 2013 8:43 pm
Panic over....... Lol.
Found a mug of PG and a couple of chocolate Hobnob`s did the trick...... winkeye
Heavy bugger when it slid off the jack and landed on my arm. :mad:
How can something so small be the weight as a small planet...
Shmallpaul
Sat May 18, 2013 11:39 pm
The real fun is getting it back on again! :D
Sat May 18, 2013 11:45 pm
I hope you put alittle bit of Loctite on the 4 bolts.
If you can't torque them up, it helps, as they have been know to work loose. 8O
Shmallpaul
Sun May 19, 2013 9:33 am
I can vouch for this.. as I found the source of my clunking sound when shifting was due to one of these suckers completely coming out, and the other about 3/4 there :mad:
