Rev limiter on a 325
philn
Fri Dec 30, 2005 8:43 pm
What is the factory rev limiter set to on these?
Thanks, Phil
welshbloke
Sun Jan 01, 2006 9:20 pm
and how would you do away with one? is it possible without chipping?
kam-325i
Mon Jan 02, 2006 12:53 am
M20B25 rev limit set at 6700rpm (i think, could be 6600)
To remove the factory rev limit, the ECU must be reprogrammed.
astondg
Well my 323 has it at 6500rpm and I think the 325 is the same but I can't be certain. I think a chip or piggyback/standalone ECU is the only easy way around it but I am not sure.
Aston
BMW E30 323i with some stuff
1:05.17 @ Queensland Raceway Sprint track
1:10.09 @ Queensland Raceway Clubman track
1:21.67 @ Morgan Park Raceway
Kos
Mon Jan 02, 2006 12:55 am
change rotor arm, some early 325's had no limter. but not a good idea. engine looses power above 6800 unles you have a mental cam but you may end up throwing a rod!!!
www.pukardesigns.com
IG Pukar.Designs
kam-325i
Mon Jan 02, 2006 1:02 am
:oops:
M20B25 is set @ 6400rpm (DME) Max power (Bhp) @ 5800rpm
