Tyre life in years?
h7fal
Mon Dec 24, 2012 1:14 pm
If a car isn't doing heavy mileage, how long should you run the same rubber. Does it start perishing reardless of remaining tread?
1988 Tech1 325i Motorsport Convertible
2005 Porsche Cayman S
pac1982
Mon Dec 24, 2012 1:19 pm
all depends where its kept and how really
1990 BMW E30 318IS (Sold)
1990 BMW E30 316i (RIP)
Grrrmachine
E30 Zone Wiki / Team Member
Mon Dec 24, 2012 1:21 pm
In Germany the TUV gives a life of six years, regardless of tread wear. After that, the tyre is scrap. This is valid even if the tyre has been sitting unfitted on a warehouse shelf for most of its life.
The issue is that the chemicals that make up the "rubber" aren't stable; they're affected by changes in temperature as well as UV exposure, and this can make them dry out, stiffen and harden over time, until it comes to crunch time and you need some heavy braking and find out your tyres have turned into Lego plastic.
All tyres have their manufacture date stamped on them as a four-digit code; the first two digits are the week, the last two are the year of manufacture. At present, any tyre stamped 5106 or less is illegal to use in Germany.
Expect this legislation to spread to other EU countries in the very near future.
h7fal
Mon Dec 24, 2012 1:39 pm
Thanks that's useful. The car is garaged and primarily used during the summer. The tyres are around 4.5 years old so I'll budget for a new set around 2014.
