followed the wiki fitting guide on here on how to fit fogs.
fitted the front n rear fog switch,
fitted the k8 relay and fuses to 29&30
fitted the front fogs.
No luck!
any ideas?
						Front fog lights not working,
- baxter-e30
i havent put the bulb in the cluster yet tbh,
i think the switch maybe at fault as when i changed over the switches and put my lights on full. the rear fog light is constantly on. but can be turned on/off when on dipped lights.
need to get hold of another switch now and give it a try
- baxter-e30
just bought some contact cleaner you mentioned of. il try it now and let you know how it goesRich320I wrote:id give cleaning the switch a try, the switches are very very robust and normally just need a clean.
				Grrrmachine
- E30 Zone Wiki / Team Member
You should be able to unplug the switch and bridge the wires to make the lights come on, to confirm that it is the switch.
									'89 325i Touring   |   Touring Resto Thread   |   In-Dash Screen install
						- baxter-e30
ive cleaned all the contacts on the switch and its still doing it.
im gonna try another switch me thinks. shame as ive got everything fitted now to have front fogs
