how much drop?
mcbonio
Tue Nov 06, 2012 5:12 pm
I want to lower the arse end of my m30 project car, it's currently got the standard 325i springs. The front height has dropped with the extra weight of the m30 and is perfect for daily driving. I just want to lower the rear so it matches up nice with the front.
How much does it need to be lowered by? What size springs do I need?
Rtaylor2208
Tue Nov 06, 2012 5:59 pm
Going on the picture I would say -30 as it looks like 4x4 suspension on the back compared to the front.
mcbonio
Tue Nov 06, 2012 6:00 pm
Lol, it handles like a fishing trawler too. -30 you think?
ndg
Tue Nov 06, 2012 6:56 pm
Be aware that there's more to a spring than ride height.
Lowering by adding weight will not change the spring stiffness, however the new rear spring will probably be stiffer than the old, and this will change the balance of the car - in this case giving it more over-steer due to increased load transfer at the rear end from the stiffer springs.
You should really aim for a stiffness increase on the front end to match the increased weight and increase in rear stiffness, but a shorter free length to give the ride height you want.
Suspension tuning is a bit of a black art unless ou have access to vehicle dynamics modelling tools like ADAMS Car.
Tue Nov 06, 2012 7:14 pm
Cut a Coil off :wink:
mcbonio
Tue Nov 06, 2012 7:15 pm
Good input ndg,
Can you recommend a shorter rear spring that would be as stiff as a stock one?
mcbonio
Tue Nov 06, 2012 7:23 pm
Rav335uk wrote:Cut a Coil off :wink:
Only thing is they are pig tailed on each end, so if you cut them the won't sit on the spring perches correctly... ?
johnl320
Tue Nov 06, 2012 7:32 pm
I had exactly the same issue with my m30 conversion. Standard 325 front springs upfront and an arse in the air, after trying a couple of options I went -30 and used the thinnest spring pads I could get.
Have you got a rear arb fitted?
mcbonio
Tue Nov 06, 2012 7:42 pm
Yeah the car was a 325i, so ARBs front and back. Why, what is your thinking?
Also, what springs did you get?
e30den
Tue Nov 06, 2012 7:47 pm
eibachs or koni would be a good move.
johnl320
Tue Nov 06, 2012 7:50 pm
Just wondered what arbs you had cos you mentioned the handling. Mine started life as a 316 so skinny front arb and no rear one at all. I think cab and touring ones may be thicker than saloons. My springs were off a breaker, no idea of make tbh.
mcbonio
Tue Nov 06, 2012 7:58 pm
The handling isn't terrible, the extra weight up front and the high rear end don't help. It would be much better if the rear was tighter, would look better too.
-30mm it is then.!
ndg
Wed Nov 07, 2012 12:18 pm
I don't know what the spring rates are for the various options I'm afraid. Generally the shorter you go the stiffer it will be to control bump movement. Go with the most road focused lowered spring you can find for the rear, and the most track focused standard height spring you can find for the front. I hate to say it, but this is one area where coil overs make life easy. Pretty much any spring rate you want combined with an adjustable platform to set the height independent of the free length.
The other way to change the balance as Johnnle30 mentions is ARB's. A thicker ARB will give moe load transfer, and thus make that end 'looser' So if it's a bit tail happy after some lowering springs you can either remove any rear ARB fitted, or beef up the front one. The down side of tuning with ARB's is that their effect is proportional to the lateral acceleration, fine if you only ever drive on a dry road, less fine when it'ss wet, as the natural balance of the car will start to come through again. You could tune them for the wet road, but then they'll be out for the dry etc.
sherb
Sun Aug 05, 2018 10:26 pm
I'm looking into finding out more information on this car having just purchased it and was wondering what setup you went for in the end on it?
Haven't had the chance to look underneath but would appreciate any help or links to any posts relating to this car.
Tue Aug 07, 2018 1:50 pm
Holy thread resurection Batman !!!!
You know, someone might just know the answer here.
sherb
Tue Aug 07, 2018 3:22 pm
Just a bit :D this is why I love owning older cars is being able to find out information about them as well as history and so on.
