I've got a 316 m10 running on the original carb. Once its up to temperature it idles erratically, with revs rising and falling.
Any ideas what this could be?
I cant find any leaks on any vacum lines , however one of the vacum lines doesn't go anywhere, it leaves the carb then joins a plastic disc but this isn't connected to anything. Is this correct?
idle issue/ vacum line identification
Pictures of this vacuum line, and car mileage.
The pierberg 2BE carb is a pile of crap. It as electronic idle, electronic choke and electronic 2nd barrell, so I expect it's one of those playing up.
You're best off spending £300 and getting the Weber replacement carb, a DMTL32/34, which is designed and jetted for this car.
Or if you're feeling brave, a Weber 32/36DGV.
teamalsoran
best thing you can do, i have fitted loads of these over the years, it usually transforms the carcapnmchl wrote:Pictures of this vacuum line, and car mileage.
only downside is the econometer thiungy wont work afterwards and your have to find somewhere to mount the choke cable
