Hopefully this isn't a silly question...but does anyone know where I can get a torx E15 female socket? I have a torx socket set but it only goes up E10, E12, E14, E16, E18, no odd numbers after E10. It also seems pretty much every other set is the same...can't find an E15 anywhere.
I know a 10 mm socket fits and is fine for screwing in the bolt, but no enough bite for torquing up drivehsaft flange bolts...
Torx sockets
Ebay is the first hit. I thought that my Halfords kit had a size 15 female socket but now I'm not so sure. Can't check until after 5 either.
I'm not sure if it is due to the E/T thing? On the Halfords site the big tool sets only list T sizes (inc 15) but no E sizes. Yet I know for sure there are female and male 3/8" drive tools.
B and M hayley gloucester branch will get you one in if its not on the shelf.Motorhole wrote:Hopefully this isn't a silly question...but does anyone know where I can get a torx E15 female socket? I have a torx socket set but it only goes up E10, E12, E14, E16, E18, no odd numbers after E10. It also seems pretty much every other set is the same...can't find an E15 anywhere.
http://www.hayley-group.co.uk/
Yeah mine are Clarke too. Had a look on the webpage though and the same, all their sets are even sizes only above E7. Will give Haylay group a try, there's one in Mancs, thanks!lamby wrote:i use clarke sockets as they are intended for all uses,have a look on machine mart and it will tell what ones.torque up fine and had them years
