Why my car feel not rigid? steer is not responsive
markus_74
Mon Sep 03, 2012 5:21 pm
hello,
need help, my car is become not rigid.
and steering is so light so it is not responsive.
can I make my steering responsive by adjust the big bolt at the rack?
and my car become not rigid because of I use 14" rim/wheel?
thank you
**BANNED**
Mon Sep 03, 2012 5:27 pm
Have a look at the rubber flexi joint on the steering column,it's just above the rack in the engine bay.
These are starting to fall apart now,been a number of zoner's mentioning 'vague steering'.
Youth is wasted on the young.
markus_74
Tue Sep 04, 2012 12:39 am
daimlerman wrote:Have a look at the rubber flexi joint on the steering column,it's just above the rack in the engine bay.
just replace the rubber flexi joint with new one 2 weeks ago after found the old have crack, but it is improve but still not rigid and no feeling to the road.
I also have do re track at the tire shop here, but no help.
I feel the steering too light and like drive on "ice road?"
also have try fill the tyre with enough air so it is harder but no change.
need advice
askjeevesplease
Tue Sep 04, 2012 1:39 am
Steering rack?
Track ends?
Bushes?
Lollipop bushes?
Could be a number of things, get under your car and have a good tug at all steering related parts and you might find one of the above is in need of dire replacement. Good luck babe. xx
Tech1 Sport, 318is, Rare Escort 1.3 RS turbo, Rust perventing BShitter.
askjeevesplease
Tue Sep 04, 2012 1:41 am
Is it snowing in Indonesia?
Have you got correct/legal thread on your tyres?
Are your tyres bold? this could lead to 'ice feel' one would imagine.
**BANNED**
Tue Sep 04, 2012 7:51 am
Tyre pressures should be around 30psi,higher will give light steering.
Just wondering if one of the 'turning' parts of the system is binding,steering wheel to column top,or a strut top mount,perhaps?
Check by popping off the track rod ends,so the system is seperated into three parts and try each one for smooth movement.
Tue Sep 04, 2012 8:32 am
askjeevesplease wrote:Is it snowing in Indonesia?
:hammer:
