M3 suspension swap - style 5 wheel issue
A4-AHV
Tue Jul 03, 2012 8:29 am
To add to my camber issue, I'm also having problems with my style 5's 17".
The fronts are catching on the callipers, anyone else had this issue. Was told they would bolt straight on. Famous last words :)
e21Jason
Tue Jul 03, 2012 9:24 am
Yes had the same problem had to run a small 2mm shim to clear the pad retaing clip on the caliper
BMW e21 track car supercharged s14 cage and fabrication by www.chizfab.com
Z3M Coupe for sale
69 Alfa spyder
