Battery is fine, changed the starter motor an its still the same, cleaned all the earths an connections, thinking its a relay now, which relay controls the starter motor?
What else could it be?
The cars a 90 316i
Thank you
I have added a large relay to my 318i M40 as I find the ignition switches do not last for too many years otherwise.Mark-W wrote:Cheers for that, does sound the same, mine turned out to be the ignition switch itself
