how do your remove dash switches?
Jungian64
Sat Mar 24, 2012 5:05 pm
Any tips on getting dashboard switches out without wrecking the dash or the switch e.g rear wash wipe ones?
Sat Mar 24, 2012 5:20 pm
Take the stereo out - you can then push them out easily.
Jungian64
Sat Mar 24, 2012 5:33 pm
Genius! Knew someone would know the quick n dirty way..
Many thanks.
Jungian64
Sun Mar 25, 2012 5:09 pm
Er...then how do you get the stereo cage out...?!
Cloggy Saint
Sun Mar 25, 2012 5:13 pm
Most stereo cages have metal tabs on them that are bent up or down into the dash it's self to keep it secure. Bend them back again and the cage should come out. Just remove the stereo though, not the cage too!
Jungian64
Sun Mar 25, 2012 5:51 pm
Thanks, figure it it out...! Cheers.
DHFiS
Sun Mar 25, 2012 5:58 pm
I took the clock out and pushed the switches through from behind. If you push the clock in my car sideways it gives enough space to pull out - no special tools.
Jungian64
Sun Mar 25, 2012 6:02 pm
..thanks for advice...always comes after youv'e done the job! ..but still appreciated.
