Rear strut brace size (help!)
JazzMan
Wed Nov 23, 2005 10:09 am
Could I ask a favour please :D
Could somebody please measure the distanced between A, B and C in the following diagram on their E30 (Saloon/touring) I would like to find out if I can use an E30 rear strut brace on the Sportster (in theory they should be the same!)
Thank you :)
JazzMan
Thu Nov 24, 2005 8:14 am
Help, any one with a tape measure? :)
astondg
Thu Nov 24, 2005 10:22 am
I just went outside to check for you. I opened the bonnet, got the tape measure lined up over the first bolts and then realised I was at the wrong end :roll: . I went to back, opened the boot, went to put the tape measure on and realised there was carpet there :( . It is night here (so it's dark outside, I realised that when I walked into a spider web I couldn't see :) ) so I couldn't see if there was any hole in it and I didn't feel like pulling it out so I will see if I can check tomorrow morning for you. I do have to leave early though so maybe not until the afternoon.
Sorry, but surely someone else knows?
Aston
BMW E30 323i with some stuff
1:05.17 @ Queensland Raceway Sprint track
1:10.09 @ Queensland Raceway Clubman track
1:21.67 @ Morgan Park Raceway
JazzMan
Thu Nov 24, 2005 10:37 am
Thank you for your efforts anyway :D - I forgot that the carpets int he way at the back!
astondg
Fri Nov 25, 2005 8:51 am
Ok, B & C seem to be the same at about 103.5cm (40.75"). I checked it twice and they both seem to be between 103 and 104cm. A is about 99cm (39"). It was hard to measure exactly because when I put my hand there to hold the tape I couldn't see exactly where I was putting it, probably between 99 and 100cm. 2.54cm in 1 inch.
That is for my 323i which should be the same as most other E30's I think, except maybe the M3?
Aston
JazzMan
Fri Nov 25, 2005 8:53 am
Thank very much :D
jens
Fri Nov 25, 2005 1:07 pm
Hæhæ
Can anyone tell me where can i find pictures and measure of
E30 front strut brace.
