what is that clunk?
e30lou
Thu Jan 26, 2012 9:15 am
hi guys, this has been happening for a few months now but hasn't caused any issues as of yet, it's just annoying. when i change from 1st gear to 2nd, i get a fairly loud "clunk" and it sounds like it's coming from the back. could it be the diff?
mongomushroom
Thu Jan 26, 2012 10:14 am
Most likely a bush or mount in the back end. Center prop bearing or diff mount bush are a good place to check for wear although centre prop bearing is a pain in the arse to get to
Black_Potato
Thu Jan 26, 2012 10:50 am
Something is probably moving about which mean either its loose or worn. I'd check the diff as there is a good chance its the diff bush, you can also check the bolts as well whilst you are there. If its not those just work outward downthe drive train, check the prop, trailing arms etc. for play.
3x S14 Rightness....
