getrag 240 m20 gearbox oil
shaun_89
Thu Jan 19, 2012 1:48 pm
I am going to be changing the gearbox oil on my 91 320i and im trying to figure out which gearbox oil is best.
Ive read on some american forums but they are conflicting between different grades on mtf and even atf in a manual box.
What does everyone use over here for the getrag 240?
Rtaylor2208
Thu Jan 19, 2012 2:43 pm
Brianmoore, just posted this two threads down:
Sounds like both the gearbox oil and the hydraulics to me.
If it's still difficult to get into first after the hydraulics are sorted, then the recognised cure is to use ATF Dextron II in the gearbox, instead of SAE80; the same as used in the E34/36 gearbox.
shaun_89
Thu Jan 19, 2012 5:12 pm
Rtaylor2208 wrote:Brianmoore, just posted this two threads down:
I dont have a problem with my gearbox, it works fine. Just wanted to know the best oil to use in it.
Thu Jan 19, 2012 5:20 pm
shaun_89 wrote: I dont have a problem with my gearbox, it works fine. Just wanted to know the best oil to use in it.
Had someone come to me once, saying that they'd changed the oil in their gearbox and now it wouldn't engage first gear properly.
I asked them to examine the old oil, if they still had it, and sure enough, it was bright red.
Yours might just be working OK now, because it already has ATF in it.
shaun_89
Thu Jan 19, 2012 6:22 pm
Ok thanks, ill just use atf dextron II then. Will it be ok to use this even if mtf comes out of the box when i drain it?
Thu Jan 19, 2012 6:35 pm
The downside of ATF is that the box will rattle more.
I'd put back whatever is already in there.
shaun_89
Thu Jan 19, 2012 7:33 pm
Brianmoooore wrote:The downside of ATF is that the box will rattle more.
How can i tell the difference? Is all atf red? If its not red its mtf?
Thu Jan 19, 2012 8:09 pm
No and no, but if it's red it's probably ATF and vice versa.
HairyScreech
Fri Jan 20, 2012 1:55 pm
iv been running atf for about 40k miles as per the suggestion, cant report any ill effects other than as said a slight increase in the rattle.
