325 radiator
How many different types of radiator can you get for the above - heard people mentioning tropical? Need a radiator for 2.5 but not sure what one has previously been in the car
Phase I - Bodywork Complete
http://www.e30zone.net/modules.php?name ... by+restore
Phase II - 2.8 stroker- Complete
Project II - 325 Motorsport Cabriolet Restoration.
UK spec - Motorsport convertible.
Is that the correct radiator? I need a tropical.
cecotto479
- Caution Unreliable Seller
- Contact:
Your car should have/did have a standard facelift M20 auto radiator, John.
1981 E23 735i
Will it fit - what's the correct radiator? Or should it have a normal 325 radiator?
cecotto479
- Contact:
Standard radiator was fitted from the factory. Tropical rad will fit. It's just a bit longer.
1981 E23 735i
Cheers Boyd - ill get in touch next week - thought you had taken a scunner to the zone.
e301988325i
Off the top of my head:johnt0709 wrote:How many different types of radiator can you get for the above - heard people mentioning tropical? Need a radiator for 2.5 but not sure what one has previously been in the car
manual,
auto,
manual with air con,
auto with air con,
tropical,
Basically a manual car can have any fitted, an auto needs an auto radiator. Manual with air con, and tropical rads are larger than the plain standard radiator.
I said:
e30topless said:
lock the wife in there
