Hi,
Will a e36 gearbox fit on my e30? (318 is)
e30/e36 gearboxes
320Touring
E36 m42 gearboxes have different ratios than the e30 ones.
E36 boxes are 1:1 5th whereas e30 boxes are 1:1 4th, with an overdrive 5th.
the box will fit but you'll need to change the diff ratio to get it geared properly..
What's the difference between an overdrive 5th and a proper 5th?
- Brianmoooore
0.81rossmc88 wrote:What's the difference between an overdrive 5th and a proper 5th?
good to know, thanks
