Rear bench
Ebdou
Tue Aug 23, 2011 10:59 pm
hi guys, is it possible to fit a rear bench (arm rest one) from a 6 pot to a 4 pot without any mods?
thanks
randomspeedfreak
Tue Aug 23, 2011 11:17 pm
yes its the same across all models
Ebdou
Tue Aug 23, 2011 11:21 pm
thanks mate
Ranchero
Tue Aug 23, 2011 11:26 pm
The engine has no relevance, it's the amount of doors you need to concern yourself with. 4-door rear bench differs slightly but will still fit a coupe and vice-versa.
**BANNED**
Wed Aug 24, 2011 1:28 pm
Upright part of the rear seat is the same on all saloons,the base differs between 2/4 doors.
Cabbies and tourings are completely different,of course.
Youth is wasted on the young.
grantorino
Thu Aug 25, 2011 12:34 am
And if you want to mount rear headrests later, all the backrests have the mounting points in them, you just need the plates the headrests slip into. The front headrests will fit the rear seat.
1986 325 ES stick shift 137,000 miles, 1973 Mercedes 280C
randomspeedfreak
Thu Aug 25, 2011 12:01 pm
Ranchero wrote:The engine has no relevance, it's the amount of doors you need to concern yourself with. 4-door rear bench differs slightly but will still fit a coupe and vice-versa.
i forgot about moredoors! whoops my bad ha
