R134A Conversion Kit
turkeysneck
Thu Jul 07, 2011 10:35 pm
Can anyone tell me what is involved with a R134A air conditioning conversion kit.
lamby
Fri Jul 08, 2011 9:51 am
i,ve looked as mine needs it and you can buy a kit for 45 quid.looks like different valves and oil.as the r12 valves are screw on to fill and r134 are push on thats it as far as i can see.
gaszman
Fri Jul 08, 2011 10:14 am
this is quite simple all you need id the new fittinf that screw on to the r19 holders looklike bikr valves . but you will need a filter when changing the gas
clipper
Fri Jul 08, 2011 10:30 am
I understood that you can replace the original R12 gas with R413a gas with only a change of compressor oil and dryer filter, without the need for a full conversion kit.
Any truth in this ?
gaszman
Fri Jul 08, 2011 10:34 am
yes this is true but if your changing the oil / gas a service would do it good and you will gettter better results
clipper
Fri Jul 08, 2011 10:38 am
Ok thanks, TBH I can't really decide if my system needs servicing / upgrading or not.... what should you see in the sight bubble ?
It's a dealer fit system, but contrary to most, I find that it works quite well but I don't reckon it's as good as it used to be. Is there an easy "check" to see if it's running properly?
Sorry for the thread-jack BTW..
turkeysneck
Fri Jul 08, 2011 11:13 am
Thanks.
