Sat May 28, 2011 10:00 pm
Cheers Brian, thats the answer I was looking for.
Used to carbs you see, not really had to deal with injectors. I wasn't sure (from reading numerous articles) whether you could visually identify the condition.
On that note, probably worth taking the intake etc off for a clean a new gasket? The reason for me doing the injectors is I've been having the old kangaroo issue at low speed etc and everything else seems to check out at present. The cars done 130k so probably worth doing these bits anyway now do you think?
I suppose its where do you stop!
89'Schwartz 320i Coupe 2.7! m-tech2
