BMW E30 Key to Remote Keyfob DIY Conversion
paris
Fri Mar 25, 2011 9:20 pm
Hi. This is my latest DIY, couldn't find a better sub-forum to post
Anyway, we will be going from this :?
To this (Remote Kit install will follow some time soon):
For 10 Euro, I got 2 duplicates of the original key. Make sure you get the duplicates with the all-metal version, not the plastic handle.
Blank blade removed for measuring:
Using an angle grinder, I cut both keys:
Newly cut key below blanks from keyfob, showing what needs to be removed in order to fit within the remote key enclosure:
Using my dremel, I started to grind just a bit each time, testing fitment.
Had to skim them about 0.5mm, don't worry though, the key won't bend!
The glue I chose to use, is super strong. Once it settles, the key will not be able to be removed from the key carrier. I had a spare keyfob for testing, and I just threw it away, they key would not get out.
Applying glue, aligning blades and letting it harden:
Excess glue is removed and blade is re-assembled to the keyfob
Now, the E30 is too wide so I was going to trim it but I don't know if it acts as a stop when the key goes into the lock, so I chose to grind the plastic housing a bit.
robbo86
Sat Mar 26, 2011 1:15 am
Awful lot of effort when a simple solution exists. A £30 kit from a company on eBay called right click will provide those very key fobs, with a BMW logo on the back, a remote central locking retrofit kit and the correct blanks for your car to be fitted into that key fob which fit perfectly.
Laurence
Sat Mar 26, 2011 1:31 am
have you got a link to that ebay company mentioned?
polsta
Sat Mar 26, 2011 3:05 am
why on earth would you want to replace a classic cars genuine bmw old school key and old school alarm fob, with a key like that :?
GWB
**BANNED**
Sat Mar 26, 2011 3:26 am
www.rclick.co.uk bud. A dam fine company with good, reliable products that are well thought out.
Then the original keys can be kept safe and suffer no more wear.
Crumbs I'm surprised I haven't gone off one one?
It must be late :D
Never argue with an idiot. They bring you down to their level then, beat you with experience.
paris
Sat Mar 26, 2011 3:09 pm
robbo86 wrote:Awful lot of effort when a simple solution exists. A £30 kit from a company on eBay called right click will provide those very key fobs, with a BMW logo on the back, a remote central locking retrofit kit and the correct blanks for your car to be fitted into that key fob which fit perfectly.
Not a lot of effort, 30 min job. I didn't know about that company though. :? will try them for sure.
cro320
Sat Mar 26, 2011 3:43 pm
nice effort but that's Audi/VW style key and that is fail
you can get E46 blanks and convert them to E30 key...that looks nice
