My BMW is the 320, and it does sound rather tappetty.
124k miles
Just had new heat shields, cambelt and filters and oil etc....
when i rev the engine...it sort of coughs, and misses, then picks up the power....
it can do this for ages, making it impossible to drive because it kangaroos....
the hesitancy/cough is always at the lower end of the throttle range, just as the revs begin to rise...
once revving, it seems to 'clear it's throat'...
i am going to take a video and put it on you tube to explain it better
320i convertible automatic...hesitancy under acceleration
- paolobianchi
How is the ignition system? New leads, distributor cap, rotor arm etc can go a long way if the current ones are past their best.
Russell A Macfarlane
Central Scotland
Central Scotland
Check all the hoses to the intake manifold for air leaks - particularly the bellows from the airbox to the throttle body - these are a common fail point and a split can lead to the symptoms you mention.
Tappety noises are something else.
- paolobianchi
Russ, Rob...
many thanks for your tips...I will look at this tomorrow hopefully.
It has new heat shields, spark plugs, distributor, rotor arm, air filter, oil filter, ht leads
I ave not looked for split hoses, so will do that....
here is a vid of what is happening...it might explain it better than i can
it starts at about 1 minute in...kangarooing
Thinking about it mate thats what my 525i E34 did when i first bought it and it was a split hose to the inlet manifold as Rob said above, had slipped my mind until he had said that.
Central Scotland
Central Scotland
