quick question guys
ash-e30
Thu Feb 17, 2011 6:52 pm
hi there ,
how do you get a rad out of a 320i?
cheers ash :D
bmw e30
craigieeb
Thu Feb 17, 2011 7:47 pm
With Tools
:teehee:
undo the water pipes, and the 2x10mm bolts that are on the top bracket.....
job done
Thu Feb 17, 2011 8:08 pm
craigieeb wrote:With Tools
:teehee:
job done
But before you do that, remove the two plastic rivets that hold the top of the shroud, unhook the bottom of the shroud from the bottom of the rad., and balance it on the fan.
mark_i
Thu Feb 17, 2011 8:27 pm
dont forget to drain the radiator coolant first...
Thu Feb 17, 2011 8:50 pm
I find that usually drains fairly well when you take the bottom hose off!
