260 gearbox
kilrone
Tue Dec 28, 2010 9:42 am
hi guys i am trying to open the gearbox in order to replace the first motion shaft bearing i have tried to press the shaft out by making up puller of sorts and so far no luck any advice would be appreciated thanks
kilrone
Wed Dec 29, 2010 3:12 pm
hi thanks for the info i have removed the c clip and i have made a press but it is incredibly tight and i do not want to break anything i am starting to worry that i might have overlooked something
kilrone
Wed Dec 29, 2010 8:28 pm
thank you your info is really good the pin that needs to be removed has me baffled i will have a look to morrow after work and see if i can find it.
