batttery help!?!
pukar
Wed Dec 01, 2010 5:21 pm
my batttery was fine a few days ago, engine always fired up first time, but now its cold, the battery seems to have been losing a bit of charge, and today, it didn't start at all.....a bit embarassing with the alarm going off! had absolutely no problems since last winter and had to charge the battery a couple of times.....no probs with normal weather.
i only drive 10 mile round trip to work, but the engine gets a good run as its mainly A roads, albeit with a bit of traffic...
i have got the battery on charge and will try it tomorrow, but is this a sign of a nackered battery, if so which one would you guys recommend?
pukar
Wed Dec 01, 2010 5:31 pm
ok....i have had it on the charger for about 15mins and the charges says its fully charged?!?!
asmith88
Thu Dec 02, 2010 10:54 am
are you sure its the battery? does the engine turn at all? will it start with jump leads or a booster pack?
1990 brilliant red 318 is
BrewCity11
Thu Dec 02, 2010 11:50 am
Have you considered the alternator? Once you get it started again, unplug the battery, see if the car still runs; use electric wondows, radio, etc, to put a load on the alternator.
Turk
