slow accelerator/ no kickdown.. i think gearbox! sorted!!!!
ruffryder
Thu Nov 11, 2010 12:15 pm
have a 325i auto and it wont go as it used to.... the story is the car started to run rough and the fuel pump was making a loud buzzing noise, carried on driving it then one morning the car started then died... would not start up.... i changed the pump (2nd hand one) and the car started, it has no reving problem and idles fine. when i put it in drive and accelerate it moves off very slow as if it dragging something..... i have changed the fuel filter no difference..... also when driving, it does not do kickdown.... any ideas????
ruffryder
Fri Nov 12, 2010 8:08 am
i think i know the answer now just need a opnion... i took the car for a drive and it dont seem like its changing gear, it seems it selects 3rd gear or something, i've tried 1st gear and still the same... gone through all gears manually (1,2,3,d) sports mode..ect. nothing... its fine in reverse... any help would be great... thinking about changing gearbox oil????
b4gga83
Fri Nov 12, 2010 2:46 pm
I had the same problem, £300 approx the problem was fixed!! (gearbox changed)
ruffryder
Fri Nov 12, 2010 6:04 pm
someone has told me to change the oil first and try another gearbox ecu...ummmm
andreia
Fri Nov 12, 2010 11:54 pm
ruffryder wrote:someone has told me to change the oil first and try another gearbox ecu...ummmm
Check the quality of the oil it should be red not brown. If you gone change the oil change the gearbox filter aswell. is worth a try alot cheaper then a gearbox
andreia
Fri Nov 12, 2010 11:59 pm
ruffryder wrote:i think i know the answer now just need a opnion... i took the car for a drive and it dont seem like its changing gear, it seems it selects 3rd gear or something, i've tried 1st gear and still the same... gone through all gears manually (1,2,3,d) sports mode..ect. nothing... its fine in reverse... any help would be great... thinking about changing gearbox oil????
The gearbox is set to select third in case somthing is wrong, as i said make sure the oil is red and check the level aswell
ruffryder
Sat Nov 13, 2010 12:34 am
will do as you u say... worth a try hey!! thanks for your help and will come back with a answer!!!
ruffryder
Sat Nov 13, 2010 1:47 pm
all sorted out... thankfully it was not the gearbox... changed gearbox ecu out one of my other bm's and it runs as it should.... sweet!! just have to find another one to replace the other one now... lol :roll:
dips346
London Meets Main Man
Sat Nov 13, 2010 3:49 pm
ruffryder wrote:all sorted out... thankfully it was not the gearbox... changed gearbox ecu out one of my other bm's and it runs as it should.... sweet!! just have to find another one to replace the other one now... lol :roll:
told sunny thats what it was lol
Theo
Sat Nov 13, 2010 3:57 pm
I have a couple here if you're interested.
ruffryder
Sat Nov 13, 2010 7:07 pm
yeah... nice one dips... as ever always helpful and knows his shit!!!
ruffryder
Sat Nov 13, 2010 7:11 pm
maybe... how much posted to tw15??
Theo
Sat Nov 13, 2010 7:18 pm
£15?
ruffryder
Sun Nov 14, 2010 12:54 pm
sounds good... what i will need to do is make sure the serial number is the same.... it ends with 059 i think but will confirm... and also to you take paypal??
thanks for your help theo325!!!
Theo
Sun Nov 14, 2010 3:49 pm
ruffryder wrote:sounds good... what i will need to do is make sure the serial number is the same.... it ends with 059 i think but will confirm... and also to you take paypal??
Yeah I have one which ends 059 - I've sent you a PM with details.
