318is Over Heating Issues!
paulie1969
Tue Oct 05, 2010 7:21 pm
Hi all, I'm new to E30s & have just bought a 318is. Getting home, I had no issues, but yesterday on my way to work, I hit a bit of traffic, & the temp gauge started to creep up to just outside the red. Once moving again, it went down to the middle of the gauge. I had this problem with my E36 M3 that turned out to be the viscous, so i ordered a new viscous. That was fitted yesterday, & my journey to work was trouble free, gauge going to, & staying at half way. I hit a bit of traffic on my way home, & the gauge started creeping up again. I put the heater on full blast, & it eventually fell to the quarter marker. It eventually went up to the half way marker again. Next course of action is replacing the thermostat, then if that don't cure it, check/clear the rad incase it's blocked. Any other things i should check for? any help or advice appreciated! :D
HJG-E30
Tue Oct 05, 2010 8:01 pm
Has the cooling system been bled correctly?
DHFiS
Tue Oct 05, 2010 8:12 pm
Have you flushed the rad through to make sure there is no sludge in it? Are youu using straight water or a mixture of water and antifreeze/coolant?
paulie1969
Tue Oct 05, 2010 9:57 pm
Well, plan of action is going to be to change the thermostat, flush the cooling system, & refill & bleed the system. How's the best way to flush the rad, with a hose & water or use one of those flush additives available?
HJG-E30
Tue Oct 05, 2010 11:06 pm
just remove radiator and use a hose until the water coming out is completely clear
Conan
Wed Oct 06, 2010 10:20 am
What about bleeding the system after? Hows that done?
'91 Sterling Silver e30 320i SE
'96 Avus Blue e34 525i Sport
'92 Alpine White e30 318iS Touring
'86 Alpine White e28 M5 (008/187)
'02 Titan Silver e39 530d Sport Touring
'54 Cosmos Black e61 535d MSport Touring
'07 Sapphire Black e61 M5 Touring
paulie1969
Wed Oct 06, 2010 6:47 pm
Well, fingers crossed, i've cured the problem. I've changed the thermostat, & bled the system, & now the temp gauge is sitting dead centre. I left it running for about half hour when hot, & it didn't move.
