325 blue temp sender
bilun777
Sun Sep 26, 2010 8:10 am
Whats the best spanner and size to remove the blue temp sender in situ. thanks..... :?
If it aint broke don't fix it!
knightmare
Sun Sep 26, 2010 8:17 am
spark plug socket did it for me. cant remember exact size
bilun777
Sun Sep 26, 2010 8:25 am
It's still in the car so limited access.
bilun777
Sun Sep 26, 2010 9:59 am
Just need the size in M.M.so I can buy one off ebay.. Ta.
Sun Sep 26, 2010 10:24 am
There's a spark plug socket in your tool kit in the boot.
bilun777
Sun Sep 26, 2010 11:04 am
Just found it in andy everett's restoration book... 19 mm steeply cranked spanner ,no room for normal sockets let alone plug sockets. :)
votivequagmire
Sun Sep 26, 2010 4:32 pm
I've used a 19mm open ended spanner to remove the blue sensor.
You have to turn it around once or twice but once the seal is broken you can usually unscrew it by hand after that.
'88 325i M20, could've done with a sunroof.
unmol
Sun Sep 26, 2010 5:10 pm
I replaced mine yesterday, remove the brown sensor and an offset 19mm ring spanner.
bilun777
Sun Sep 26, 2010 7:10 pm
unmol wrote:I replaced mine yesterday, remove the brown sensor and an offset 19mm ring spanner.
Thanks thats exactly what I decided to do .Come on Brian you've never taken it out with a plug socket in situ... :mad:
Sun Sep 26, 2010 9:07 pm
Never said I have! I was answering a question as asked.
I usually try with an open ended spanner held at an angle first, but if it doesn't move easily, I take the brown one out.
