13 Button OBC and Overhead check lights
rmurphy520
Fri Sep 24, 2010 2:45 pm
Hi
Forgive me if this has already been answered on this forum.
Can a 13 button OBC be installed into any e30? I have a 316i '91
Also, are the overhead checklights part of the 13 button OBC, if not can these also be installed too?
cheers
baur320
Fri Sep 24, 2010 2:48 pm
The obc needs the correct chip for a 4 pot.
The overhead check control is separate, not sure what's involved
Current E30 325i, E63 630is.
Morat
Fri Sep 24, 2010 2:49 pm
The overhead check lights are separate to the OBC, but not many people seem to bother retrofitting them.
Fri Sep 24, 2010 2:55 pm
Overhead check panel is part of the MAIN body loom, only available on 6 pots IIRC. Complete loom swap which is a bit of a mission 8O
rmurphy520
Fri Sep 24, 2010 11:24 pm
Ok so if I was to buy the whole kit with all the trimmings it can be done?
Fri Sep 24, 2010 11:31 pm
Yes it can be done, purchase the whole complete kit and retro fit it. There's a guide in the Zone Wiki
rmurphy520
Fri Sep 24, 2010 11:35 pm
Happy days. cheers mate. Is it much work?
Fri Sep 24, 2010 11:37 pm
Couple of hours at least i'd say. Just make sure you get a 4 pot coding plug for it or buy a kit out of a 4 pot.
rmurphy520
Fri Sep 24, 2010 11:48 pm
Sorry mate if this is dumb. What does that mean? (4 pot?)
Fri Sep 24, 2010 11:52 pm
4 cylinder i.e. 316/318 :)
rmurphy520
Fri Sep 24, 2010 11:59 pm
surely surely sorry :?
Sat Sep 25, 2010 1:54 pm
OBC is a simple retrofit.
Overhead check panel requires the whole of the main car wiring loom to be changed, from the front RH corner of the car to the back RH corner, all the way back the LH side, plus several branches, including the fusebox. After all that, there is still no provision for an oil level sensor on M40 engines.
rmurphy520
Sat Sep 25, 2010 11:48 pm
Thanks for a very detailed description :D I will definitely go about the 13 button OBC and maybe the next e30 i buy will have the overhead check lights :)
