center prop bearing - ignore, now sorted
TouringMatt
Sun Aug 29, 2010 5:22 pm
Just fitted a brand new center bearing and carrier, everything to the book. Done a less that 1 mile test and getting bad vibrations. Took the prop back off and i can move the bearing, it rotates fine with no noise but if i rock the carrier back and forth a can feel movement and see it between the inner race and the dust seal.
I'm assuming this is not right??
Any help appreciated
Matt
Adil786
Sun Aug 29, 2010 7:21 pm
this might sound stupid, but did you tighten the carrier nuts up? just asking cos it shouldn't move fwd/back? or do you mean just the bearing itself moves? cos a little movement is normal, but I'm talking a small amount?
TouringMatt
Sun Aug 29, 2010 7:43 pm
It was just the bearing itself, i've since compared it against the one i had took off which also has some movement, more than i would have expected tho
Thanks for the reply anyway, its all sorted now, my own stoopid fault, reconnected the prop halves 180degs out, 90 mins for a prop off/on job tho, im getting faster in my old age :mad:
Man what a shitty weekend its been :roll:
Matt
Adil786
Sun Aug 29, 2010 7:45 pm
is that with the exhaust on or off? that's a good time indeed!
StuBeeDoo
Sun Aug 29, 2010 8:04 pm
TouringMatt wrote:90 mins for a prop off/on job tho
Bet I'm not that quick when I do mine next weekend. I'm allowing all day.........
TouringMatt
Mon Aug 30, 2010 2:08 am
That was 90 mins from drivable to back off the stands, i did cheat by dropping the exhaust from the manifold as one piece
Stu - i actually started the job Friday night, done prop bearing, gearbox linages + short shift and changed the gearbox fluid, interrupted by rain, darkness and few trips to get Mrs TouringMatt to/from hospital.
A day is plenty! Did my fuel tank in 12 hours, just dont get your prop alignment wrong :o:
Matt
