Blown head !
RegTourist
Fri Jul 09, 2010 9:06 pm
Hi the usual story of Bailies in the oil etc engine has done a hard 180k so not really worth changing head etc ....have seen recon engines from Drop The Retro for £600.
Anyone know the guy (maybe he is a member!) or have any other thoughts?
Fri Jul 09, 2010 9:10 pm
what engine is it ?
if it's a 325i I have seen bottom ends with 300k on the clock in perfect order ! only a head change may be needed?
bilun777
Fri Jul 09, 2010 9:39 pm
Mine was running like a dream with are badly cracked head. On removing the old head every bore had it's honing marks clearly visible. Just run in nicely at 136,000 miles.If you can find a good complete engine that might be a different story.Try a wanted Ad :D
If it aint broke don't fix it!
town325i
Fri Jul 09, 2010 11:07 pm
Well if its a 325i m20b25 i have a pressure tested and skimmed head for £175 posted
E30_Crazy
Sat Jul 10, 2010 12:38 am
Now is that a fully assembled head, or just the case?
town325i
Sat Jul 10, 2010 12:07 pm
Its the head and valves it has no cam or rockers as they were worn
