Help, should of checked before I started! just bleed the coolant on my 325 touring.
Having refilled it went to the bleed screw and have found the head of the screw is messed up. (and for once not my fault) any ideas? any other way to bleed the system.
Very stuck as have to do a 100 mile trip tonight!
bleeding screw!
jimmyspeed
make sure your mole grips still have the teeth between the jaws , messed about for ages trying to get a brake bleed screw off - tried another set and was easily removed
