I am looking for some ideas to help solve a problem with my 1987 E30 325i sport.
I bought the car from a guy who had owned the car for 5 years. The test drive seemed absolutely fine, as did the driving subsequently for an hour or two afterwards. It ran perfectly and accelerated cleanly.
However, I was driving the car in the evening when all of a sudden it spluttered and cut out. The engine would turn over but would not fire up again, so I got my friend and brother to push the car to see if it would bump start, which it did but it ran extremely badly.
It will just about idle and drive at around 1,000 revs but as soon as I try to accelerate it becomes extremely jerky and with too much throttle will just cut out again. I managed to drive it home slowly (about a mile) and park it up.
Strangely, there is no spark at any plugs when cranking, including the main lead from the ignition coil, so I have tried the following:
- Replaced with a new coil. (Both coils gave exact same reading with multimeter anyway and as Haynes spec)
- Replaced the ECU with another 073 ecu (Motronic 1.0)
- Tested both crank sensors and checked with a multimeter as Haynes spec
- Checked a main fuse that runs on a separate direct wire from the battery.
- Checked all relays and fuses that I can find either by inspecting visually or swapping out. The only one I have not tested is one of the two relays under the bonnet that are mounted on top of the near-side strut as I do not have a spare.
I am completely stumped and it took me weeks to find the ECU I hoped would fix it, with no success. To me the symptoms I am experiencing seem quite strange and must indicate one of a few remaining answers. The only other ideas I have (mainly from research on the net) are:
- A dodgy earth somewhere
- A bad relay
- A lose / broken wire
- Pickup on crank may have come off
- ECU (I may have been sent a dodgy replacement as I have no idea how to test)
Do you guys have any ideas?
I have a guy coming to look at it next week to see if he can diagnose it but if he is stumped I will probably just scrap it. Seems a shame to scrap a genuine E30 sport as I am sure these are getting rarer.
Thanks in advance guys. I appreciate you even reading this long post
 Email FTW
 Email FTW
